Command not powering on
Old Nov 9, 2010 | 02:30 PM
sbaig2's Avatar
2008 CLS550
Hello, I have an 04' Mercedes S430. I installed a motorola IHF1000 bluetooth car kit last night. I pulled out the command unit to see if I could find the mute wire so I can hook up the connection. I took the connector out from the back of the system but could not locate the wire. I then just put everything back together and now my command wont power on. I was searching different threads and they said to check the fiber optic loop. The weird thing is when I took the connector out the fiber optic light was blinking then went away. It was not steady at all. I am not sure if its supposed to be a steady red light. I have checked all the fuses related to the command and navi system. Also, tried unplugging the battery terminal for awhile...still nothing. Could anyone please help me out?
Thanks!!!
