01 S500 Front Brake Pads
The dash indication "brake lining wear" will not go away. Any special tricks to get this to shut off without taking it to the dealer?
Thanks.
or, just have the dealers do the whole thing.... do they routinely recommend doing the rotos on each pad change?
j.rho
01 s500, 30K, on orig. pads still, they squeak a bit in the morning, reversing out of the garage....
If not, you should be able to do a DIY brake pad replacement with no issues.
If it is on, you'll need a sensor which is pretty easy to install, plug and play.
