Manual Shifting...
Old Jan 8, 2011 | 07:48 PM
Vabene7's Avatar
Garage Temporarily Empty
Arrow Manual Shifting...
Can you manually shift an 05 S600?
My gear shift lever shows a D+ and D- but the owner's manual states this feature is only for an S55...
Thanks for weighing in.
-Chris
Old Jan 9, 2011 | 10:07 AM
Becks Imports's Avatar
Former Vendor of MBWorld
Yes, once in "D" just tap shift lever right or left to change gears up or down. This may work only when sport mode is selected (the button on the left side of the shifter surround) but I'm not sure, it might work in all modes.
Bruce
Old Jan 9, 2011 | 11:36 AM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
I cannot speak to the S600, but the feature worked in my '00 S500 and works in my '05 S500. It is not an S55-only feature. The reference may be to the shift paddles on the steering wheel of the S55; the other models use the shift lever.
Old Jan 9, 2011 | 07:04 PM
Vabene7's Avatar
Thank you guys.
For some reason it will not let me shift on the fly. But when I started the vehicle this afternoon, I could see the gears moving as I tapped the shift knob left and right.
Just need to do some more experimenting.....
Old Jan 9, 2011 | 11:08 PM
rondocap's Avatar
Mercedes S55 AMG
You should be able to do it. From 1st, the car pulls a bit stronger I feel than when it is just in drive. Gives it a rough, awake type of feeling. You can hit the limiter to just remember to shift! (at least in my S55 that's how it is)
Old Jan 10, 2011 | 10:37 AM
Trinsoca's Avatar
2005 S500
It works fine on my car and I only drive in the C mode. so it should work on yours in any mode.
Old Jan 10, 2011 | 10:49 AM
Speedriven1's Avatar
Speedriven
The slow response and computer-overrides are some of the issues we address with our TCU software upgrade, which gives you a more "true" manual mode.
