2000 S500 wiper blade inserts
I've been searching for some bosch wiper blade inserts for my s500 with the old (non aero) style wipers without luck.
Does anyone know where I can source them?
do you have the big heavy bosch metal blades? They are about $70 each online or you can just buy refill rubber insert here, 2 pack for $20
http://www.autopartswarehouse.com/sk...ts+%26+Mirrors
Pretty sure thats the one. They sell the whole metal blades too.
Also if your local Firestone sells Bosch blades, get their 28 inch ones with the thin metal frames, cut the thin metal to remove the inserts and they will pop right into your MB thick metal blades. Thats what I did before I discovered the cheap rubber inserts are sold separately.
tusabes - would u know if 2001 s430's come stock with the bosch big wiper blades???
i cant seem to find a high res picture showing any part numbers, maybe i do have them and just refill inserts??
"Also if your local Firestone sells Bosch blades, get their 28 inch ones with the thin metal frames, cut the thin metal to remove the inserts and they will pop right into your MB thick metal blades. Thats what I did before I discovered the cheap rubber inserts are sold separately."
