need help with lock/pump/actuator
Old Mar 25, 2011 | 02:47 PM
dannylv's Avatar
1999 s320
Hi i'm a newb
I have a 99 s320 and no locks,trunk or any lock control from inside switch.
I have reset the pump(powering down),when powered back up it ran for about 30 seconds and won't do anything any at all.
Can I or has anyone ever replaced the factory actuator with and electric actuator and new keyless system?
My main concern is if I remove the actuator will the lock mechanism still work properly?
thanks for any info
Old Mar 26, 2011 | 10:56 AM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
Assuming you are located in Europe, since you have a '99 S320, you likely have a leak somewhere in your door/trunk locking system. Listen to see if there is a hiss at any door lock or the trunk lock; if so, that must be fixed.
