how to get to rear shocks to check for leak s430
Old Apr 22, 2011 | 09:09 AM
s430mp's Avatar
s430
how do i get to the rear shocks to check for air leaks on my s430, checked front good to go. replaced air pump, but the car still lower after sitting for a few hours. need to check rear for leaks
Old Apr 22, 2011 | 10:45 AM
classyS's Avatar
2001 S430
valve block.
i had similar question, is it lowere on one side??
Old Apr 26, 2011 | 11:17 AM
arod2303's Avatar
mines is lower on one side .how do i get to this valve you mention that is blocked?
thanks in advance
Old May 4, 2011 | 02:48 PM
MoonLite's Avatar
ML350 '06 & S430 4Matic '04
Anybody know and don't mind to take time to answer this question?
thanks in advance
I have the same problem; My rear passenger wheel sit more than 1/4 inch lower than other side? It's about 3.5 inch from tip top of tie to the bottom of frame fender arch.
