S430 windshield washer inoperable
Old Apr 22, 2011 | 05:34 PM
VMAX7's Avatar
2000 S430, 2000 S500 Both Brilliant Silver!
Unhappy S430 windshield washer inoperable
Hey guys, my 2000 S430's windshield washer is inoperable. When I push on the knob on the left-hand side of the steering column, nothing happens, only the wipers work, but the motor to spray water on the windshield does nothing.
I pulled the fuse and disconnected the battery but it still does not work.
Does anyone have experience on how to fix this issue?
Old Mar 2, 2012 | 07:39 PM
ccopmp's Avatar
2006 E500 & 2000 S430
Did you get the washer working?
I have the same issue, the washer fuse was blown, I replaced it but no improvement.
Old Mar 4, 2012 | 09:26 AM
Fraser's Avatar
A Mercedes obviously!
Replace the pump. About $30 for the part and takes about 20mins to do.
Old Mar 4, 2012 | 10:04 AM
Quadcammer's Avatar
96 and 08 911 turbos
+1 piece of cake
Old Mar 4, 2012 | 11:09 AM
shop14's Avatar
S600
washer pump
first thing is to check a see if you have power going to the pump, if you do then the pump is bad. if not check the fuse but if the fuse is blown its for a reason which could just be a shorted pump or an electrical issue.
Old Jan 19, 2015 | 10:33 PM
RostovMB's Avatar
2001 Mercedes-Benz s430
Where did you find the fuse? I'm having the same problem. No motor sound. 2001 s430
Old Jan 23, 2015 | 10:24 PM
RostovMB's Avatar
I think the solution is to press the button a little harder. Seriously. First click: Wipers, Second click: Window Washers spray. I wasn't the first to realize this way later.
