Pic of the driver-side fusebox needed
Old Apr 26, 2011 | 09:06 PM
Wolfman's Avatar
Super Moderator
Hi,
I need your help!
I was looking for the part number label of the Airmatic ECU which is located in the driver-side fusebox.
To do that, I disconnected the cables and pulled both control modules located in the fuse box (I thought that I had taken pictures before to make sure I don't mix up connectors).
Guess I was wrong. I can't find the images and both control units have interchangeable connectors. Stupid me!
Can anyone with a 2000-2001 S500 (or maybe later as well) please take a good close-up of the cables in the fusebox so I can make sure that the right connectors go onto the proper ECU? I need to see the colors since there are no other markings on the connectors that I can see.
There are 3 connectors per ECU (those large 1" wide aluminum boxes).
Thanks so much in advance!!
Old Sep 18, 2024 | 04:01 PM
a6000000's Avatar
S-KLASS W220 (.025) 320 CDI , 2004 , HSN 0710 , TSN 579
w220.wiki/Fuses
