Harmonic balancer blew out! (long)
1 Post
2000 S500 Brilliant Silver, 1990 BMW 735iL, 1971 Pontiac Trans Am 455 HO, 1976 Pontiac Formula 400
My balancer seperated this evening. While driving on the highway, I heard a sound that sounded like I ran over a peice of metal and it hit my inner fenderwell. Shortly thereafter, I noticed an unusual smell, maybe hot or burnt rubber. Got home. Then drove off again, not expecting that anything significant was going on. After a bit the battery light came on intermitently, then more often. Water temp became a tad high (upper 80's), steering started to go, battery light came on constantly, then temp started to rise rapidly , shut it down.
The motor was hot, overflowed a bit, but quieted down pretty quick. The outer balancer was off and wedged up against the fan. Belt was still on everything else. So, hopefully there is no major damage. I am most concerned that the engine got hot.
Is this a common problem on S class, and is it likely that it did heat or other damage to the internals?
What year is your S Class?
The crank pulley on 2000 and 2001 mercedes are notorious for failing. And everytime it does fail, it's pretty disastrous. Your dealership should be familiar with this flaw.
1 Post
Mine is a 2000 S500 with 40k miles. Fortunatel, I wasn't pushing it hard. What a PITA! I was planning on getting my illuminated door sill on tomorrow (all 4 doors).
So much for that
So much for that
![Mad](https://mbworld.org/forums/images/smilies/mad.gif)
