Rear passenger window coming down
Old May 19, 2011 | 10:08 AM
Tmarros's Avatar
2012 E63 AMG
So this morning i come out and see that it had rained a bit and my rear passenger side window is open about 1/2 an inch and this is about the third or fourth time i noticed this same window being opened this small amount. Oddly, it always occurs after/during the rain. The one rainy day i was going for a haircut and i put it up before i left the house and then once again when i got there. I came out and it was down about 1/2in again. Any ideas on what the issue could be and the fix? Thanks in advance for any help.
Old May 19, 2011 | 08:19 PM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
You can try the "resets" (when things don't work) in the W220 S-Class Encyclopedia at http://www.benzworld.org/forums/w220...tart-here.html
Other than that, it may be a bad door control module. They are very sensitive to water.
Old Nov 4, 2011 | 09:10 PM
nlieber's Avatar
cl500 2001
My window is dropping a little more than usual when I first get in the car and not closing. I have to close it with the switch. I was wondering if you discoved the cause of your problem?
