Lowermyairride Help needed!
Hi Guys,
Rather new here, clearly, I have an S320 CDI and just installed the adjustable links from lowermyairride.co.uk and i have a small problem...
As great as the car looks, its too low, so it will be getting adjusted upwards.
The problem i am having is that the button to raise the airmatic (car with upward arrow) is not working, there is no movement up or down at all.
Is this because the links are so low that they have hit a cut off point of sorts? I didnt touch a single hose to dislodge anything so i assume its bottomed out? on 18 inch rims the entireity of the tyre is hidden and the mudflaps are rubbing if i sneeze in the car![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
![](https://mbworld.org/forums/attachments/s-class-w220/210203d1305908452-lowermyairride-help-needed-photo.jpg)
Seems to have lowered a bit when it settled and after a motorway drive too
Any tips?
Thanks in advance!
Any tips?
Thanks in advance!
Turns out in putting in the new linkage on the rear I managed to have the sensor arm pointing about 5 degrees downwards, once lowered one end popped off, effectively disabling the sensor.
Popped it back on and lengthened it 5mm, angled it upwards and it stayed on, so far. Similar problem as Pete23 was posting about except my sensor was just disconnected, not faulty!
