Accidently re-used oil plug copper washer
Old May 25, 2011 | 08:41 PM
tuflon's Avatar
w220
Sealed fine but I didnt realize it was one time use until later reading on the forums. No leaks though, think im fine?
Old May 25, 2011 | 11:07 PM
Supergenius40's Avatar
2001 S500
I changed my oil a month after I purchased my 2001 s500. I noticed the plug did not have a washer. It did fine without one so I would do a short oil change cycle and replace it if you are concerned.
Old May 26, 2011 | 12:04 AM
chpsk8's Avatar
2003 S430 2008 GL450
If it's not leaking now, you're fine. No worries.
Old May 26, 2011 | 02:43 AM
desired_speeds's Avatar
2007 SL55 AMG
its fine. shop don't usually replace it when they do oil changes anyways
Old May 26, 2011 | 06:12 AM
OK55's Avatar
Mercedes E55 AMG (2006), Mercedes 560 SEL (1991)
Some people overtighten the plugs and flatten the washer beyond 're-use' level. I believe this is why MB classified it as 'single use'. In your case it doesn't seem to have been the case. So as long as it's not leaking you're fine.
Brgds
Old May 26, 2011 | 07:35 AM
Quadcammer's Avatar
96 and 08 911 turbos
i've flipped them over in a pinch.
It might weep a bit, but that should be it.
Old May 26, 2011 | 10:07 AM
tuflon's Avatar
w220
Thanks a ton guys! I was all worried haha. Perfectionist here I guess.
