Speedo locked at 210 kph
Old Jul 30, 2011 | 02:11 AM
drummerdimitri's Avatar
Mercedes s350
Hello people,
I have a 2003 s350L and for some reason the speedometer is locked at 210 kph even when the speed limiter is off. I've tried resetting all the settings, played with the cluster light intensity, but nothing worked. I know for a fact that the lights past 210 kph work because they light up as the engine is starting, but then as soon as it starts idling, the speedo lights only reach 210 kph instead of the entire 260 kph range. Does anyone know a way to fix this?
Thanks!
Old Jul 30, 2011 | 06:18 AM
Frank_S500's Avatar
SL63 (R230), CL500 (C215), SL55 (R129), CE300-24 Cabrio (A124)
Originally Posted by drummerdimitri
Hello people,
Thanks!
Hello User.
Reading the manual might help.
Keyword "winter tyres limiter".
Cheers, Frank
Old Jul 30, 2011 | 07:23 AM
Sher Judge's Avatar
2017 991.2 Turbo PDK 2017 C63S Coupe Ceramic Brakes 2015 CLS63S AMG Full House
+1
Old Jul 31, 2011 | 10:54 AM
Mercedes s350
Thanks for the response, but I don't have the permanent speedtronic function on my car. Does anyone know another way to solve this problem?
Old Aug 1, 2011 | 09:48 AM
Mercedes s350
BUMP!
Old Aug 1, 2011 | 10:13 AM
Supergenius40's Avatar
2001 S500
Does the other gauges work? Were you using cruise control when it happened? Have you checked your fuses for the instrument cluster?
