Temp 110 degrees outside my s430 AC drivers side stuck on heat!!!!!
I suggest that you go over to BenzWorld for this issue, and post the question there - not because BW is better, but because I know of some of the members who are MB techs. www.benzworld.org. I am not as familiar with which members here are techs.
While there, look for any post by member eric242340 (there is one at http://www.benzworld.org/forums/w220...-airmatic.html) - send your question to him in a private message, as well as posting it in the open forum. You send a private message by clicking on the screen name of the individual in the "avatar" area, and selecting the "private message" option in the drop-down menu.
Eric is a moderator on BW; he also owns a Mercedes repair shop (in China), and is very knowledgeable and responsive to requests. He will likely be able to help, and very willing to do so. He may have MB shop diagrams related to the problem; he can tell you the name of the part (it will be on the diagram) and the part number.
If a part needs replacement, and once you have it identified by part number, I suggest checking with Potomac German Auto, the largest Mercedes breaker yard in the U.S. They have an extensive parts catalog online - but it is so vast it is hard to use. I suggest giving them a phone call instead. http://www.pgauto.com/- their pricing will be far lower than new. However, if you want a new part, there are other parts sources listed in the W220 S-Class Encyclopedia discussed below.
You can also sign up for the Mercedes Electronic Parts Catalog (EPC) - it is free, but you do need a credit card. You will not be charged. The EPC has exploded diagrams of component assemblies, as well as part names and numbers. Often, you can figure out a repair just by seeing how things go together. http://epc.startekinfo.com/epc/start.jsp Another source is AllData, a subscription service - but AllData is sometimes not as complete as the EPC. I would look up the EPC diagrams and part numbers for you myself, but I use a Mac, and the EPC is not Mac compatible.
Last: As a W220 owner, I invite your attention to the W220 S-Class Encyclopedia. It is a categorized listing of the best of the informational and DIY threads that I could cull from the 2000+ links that I have referenced in my bookmarks. While there is one on MBWorld, some members would not cooperate with my requests not to use it as a discussion thread, but to preserve it as a research tool. As a result, I no longer update the one on MBWorld. However, I do update the ones on BenzWorld and on MBCA (Mercedes Benz Club of America) because as a moderator I can "lock" the threads and keep extraneous posts out. See http://www.benzworld.org/forums/w220...tart-here.html and http://www.mbca.org/forum/w220-s-cla...dia-start-here - there you will find more information on MB repair.
Good luck to you!
