Noise from engine compartment?
Old Sep 8, 2011 | 10:24 PM
Herbertm's Avatar
s430
Sounds like rattling noise. At first suspected dash fan but persists when fan is switched off. Started about a month ago. Today the noise persisted when engine turned off. I raised the hood and it seems like it might be coming from the large silver round box mounted near the driver. Anyone have any ideas or similar experience?
Old Sep 9, 2011 | 09:49 AM
Herbertm's Avatar
s430
Noise continues
Posted last night about noise in engine compartment. This morning the noise continued. Motor off, key out so I assume was making this noise all night. Sounds like rattling and static.
Any ideas?
Old Sep 10, 2011 | 10:26 AM
tusabes's Avatar
Mercedes
Uh oh. Sounds like your airmatic pump was running when it shouldn't be . This is due to a defective relay. Your pump is likely burned out now.
If the car is not slammed to the ground already drive it straight to the mechanic because it will soon drop so low it cannot be safely driven or even towed or flatbedddd without damage
Old Sep 10, 2011 | 10:32 AM
tusabes's Avatar
Mercedes
If the pump is still making noise , its not burnt out yet- immediately pull the relay or disconnect the battery until you get a new relay.
See the sticky start here thread this I's a common problm I keep a relay in the car in case mine ever goes out
Old Sep 10, 2011 | 11:15 AM
redcoupe's Avatar
11 ML350
So is the noise on the driver side or the passenger side? Because the airmatic pump is on the passenger side under the headlight.
Old Sep 10, 2011 | 12:45 PM
Herbertm's Avatar
s430
noise
So here's the thing. The noise sounds like static and rattling. Weds. evening I turned the dash fan off and the noise went away. Thursday evening I turned the fan off and the noise persisted, even after I turned off the motor!
The noise persisted all day Friday with the motor off. Sounded like a loud-ish static, like a radio which can not tune into a station, sort of. Friday evening I moved the car and the noise stopped! Came on when I turned the dash fan on and then went away when I turned the fan off.
Today, Sat. the noise only persists with the dash fan on. The noise does not get louder with increased fan or if I rev the motor.
The noise is seems to come from the area in on the drivers side and kind of where the brake vacuum box is.
I showed it to a certified MB mechanic on Weds and this morning and he told me not it's the fan and not to worry about it. I sure would like to diagnose the issue but do not want to spend a lot of money doing so.
I am concerned if it's related to the air shocks. Esp. if once they go I can not tow the car. The what?
Old Sep 10, 2011 | 01:39 PM
redcoupe's Avatar
11 ML350
With out being there and hearing the noise I couldnt really say what it is but it def doesn't sound like the airmatic pump
Old Sep 10, 2011 | 01:49 PM
Herbertm's Avatar
s430
noise
Thanks, I appreciate your response and input. For now, I'm going to wait and see if something else develops.
Old Sep 10, 2011 | 08:02 PM
tusabes's Avatar
Mercedes
Well if the noise is going on and off with the fan then it doesn't sound like it's the airmatic pump
Has your car been out in the rain or car wash recently?? Something may have shorted out from getting wet
Old Sep 16, 2011 | 11:50 AM
Herbertm's Avatar
s430
noise continues
Thanks for your response. Now it is definitely linked to the fan. When the fan is on there is rattling noise which goes away when the fan is off. For now, I think that I'll live with it. Doesn't seem worth it to remove the dash to address this.
Old Sep 16, 2011 | 02:10 PM
DAMIT's Avatar
2000 S Class & 2004 SLK
If you are sure that is the Heater Fan (Although how it was still running when switched off is a mystery!) It is a common problem. The result of a blocked drain in the air intake, which allows rain water to fall on the motor fan causing corrosion on the main fan bearing over time.
Relatively easy to get to from under the footwell, but as expected expensive to replace!
Can be purchased new on fleabay most days saving a third on stealership prices.
Old Sep 16, 2011 | 02:21 PM
Herbertm's Avatar
s430
noise
Thanks, I'll look into it.
