ticking noise
Old Sep 21, 2011 | 10:59 PM
hardwork s-430's Avatar
s-430 mercedes
ticking noise
Okay guys and gals my 01 s430 battery died monday morning at home so i got AAA to give me a jump it turned over with no problem on the first try. so i let it charge drove it to work and around town mon tue. But wed the battery died again okay no problem i went around town trying to price out a good battery noing it's going to run me around $150-200 found a battery at good year for around $170 i think it was a interstate. so i come back home to take the battery out for the core before i start i here a ticking noise comeing from the front of my car i open the hood it's not comeing from under the hood it's comeing from the brake rotor area so im thinking maybe it's the sensor because my brake pad were visit a workshop was on. so i took the batter out thinking this will stop the noise. battery out the noise is still there. any suggestions?
Old Sep 21, 2011 | 11:41 PM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
Your alarm system has a separate battery that is integrated into the alarm horn. It may be dead or dying; if so, the entire horn must be replaced (it's not awfully expensive). http://www.benzworld.org/forums/w220...ease-help.html - also there are links in the electrical system portion of the W220 S-Class Encyclopedia at http://www.benzworld.org/forums/w220...tart-here.html
Old Sep 21, 2011 | 11:55 PM
s-430 mercedes
Okay skylaw thanks for the info im going to put the new battery back in thru. i will keep the fourm informed.
Old Sep 22, 2011 | 10:18 AM
Skylaw's Avatar
PS - if your (main) battery keeps dying, look at the links in the Encyclopedia dealing with that issue (excessive quiescent drain).
Old Sep 22, 2011 | 05:11 PM
s-430 mercedes
okay i just put the new interstate battery in paid $155 for it. alarm was the first thing to go off sofar everything else is working normal evan the cd changer started working again it stoped working for some reason about 3 weeks ago no it's good. the abs light is on right now and the dash lights are going crazy so ima see how long that last hopefully all that go's away in afew days.
Old Sep 22, 2011 | 05:19 PM
xexpo's Avatar
2000 S430 140k (07/11)
You need to do the reset as per the Encyclopedia above after battery replacement.
Old Sep 22, 2011 | 05:29 PM
s-430 mercedes
Okay thanks xexpo ima go do that before work thanks
