airmatic shock options - reseal kits???
Old Sep 29, 2011 | 11:34 PM
vdubpower's Avatar
i drive them all, fast and hard
so i took it too a indy shop and they said the shock is bad, and thats why, the front right was down .
this mornnig i noticed the car did level , but i guess the shock fills up and then leaks
what options do i have besides 1500 for a new shock
whats the deal with these reseal kits, do they work
Old Oct 9, 2011 | 03:58 PM
earz04's Avatar
04 E500 4Matic
http://www.arnottindustries.com/?gcl...FVPGKgodI0HCbg
will give you the same performance and ride. only for front shocks so you should be set.
Old Oct 9, 2011 | 04:00 PM
earz04's Avatar
04 E500 4Matic
may want to make a move on the repair sooner than later, with it leaking it could make your pump run harder/more often which could cause the pump to burn up and add another $450 to your bill.
