2001 S500 missing B pillar trim gasket. Part #?
2001 S500
I'm missing this little black rubber piece. Can't seem to locate the Part #.
Anyone know if I can get this piece without buying the whole solid piece below it?
2001 S500
Thanks,
David
2001 S500
Thanks,
David
2005 S500 4-Matic, 1978 450SL
The piece is glued to the B pillar metal trim, and is sold with it. No separate part number. See http://www.benzworld.org/forums/w220...ubber-cap.html
The metal trim is held in place with a super-sticky glue. You will destroy the old trim when you remove it. Be sure to get ALL of the old glue off, or the new piece will not fit properly. I used Goof-Off and nail polish remover for that task.
2001 S500
That's a bummer. How far down does that little rubber piece go?
