Is this a common problem after dead battery
windows express mode, clock, roof , ESP and the clock, but it is your secondary problem.
After jump start (which in itself may make the electronics go berserk) you still have a weak battery, that is your main issue.
If it is old, get a new OEM battery. If it is not too old, disconnect and charge it and give it a try. Lots of unrelated malfunctions are typical symptoms of a is weak battery.
Measuring the voltage in itself is not conclusive, your meter may show 12.4 and it can be still weak for your power thirsty electronics.
