Rattling from aspirator motor
96 and 08 911 turbos
Afternoon gents.
I have a slight rattling from my aspirator motor in the roof console.
Took it all apart...and haven't slightest clue what could possibly rattle.
No separate part numbers in there, just a circuit board with aspirator motor/temp sensor.
Board itself runs $307, which is stupid.
Any thoughts?
Thanks.
Any thoughts?
Thanks.
Afternoon gents.
Any thoughts?
Thanks.
Any thoughts?
Thanks.
When I connected mine to STAR about a year ago it said something about S- valve something and I did search on the forums for it and it led me to the sunroof panel .. everyone was stumped as well. That noise comes and goes for me too. I think that could cause battery drain.
Also looking for an answer for this..
That's the console which has the sunroof controls and the lights right.
There is not much in there. The pushbutton contacts for the lights, the aspirator fan, and the sunroof switches.
I could shake the snot out of the board(to which the aspirator fan/sampler is soldered) and barely a noise at all.
The only noises I heard were when you shook the actual plastic console. All those little switches float in the plastic with little tabs. I put a little dielectric grease under each tab to provide a cushion and prevent plastic on plastic rattling.
I also used spray electronic cleaner to get all the nasty dust outta the aspirator fan and thermister. You can shake it pretty good without causing any real noise.
Lets hope this fixed it, because I'm not sure I want to pay $300 to fix this minor noise.
Yeah, that is the correct console.
I only hear it in the winter when I start the car for the first 3-5 minutes until the cabin temp raises.
