"Battery Charge Visit Workshop" Insight Needed
Old Feb 4, 2012 | 01:02 AM
OCKlasse's Avatar
MBworld Guru
04 CL55, 05 E500S4, 15 BMW i3 REx
Hey guys,
My girlfriend's mom's 2006 S350 had this warning message appear on her dash on the way home in red. I looked at the voltage via the cluster, and the car had 12.2V before being started and then held a constant 12.0V with the vehicle running.
Is this indicative of a faulty battery? Could it be the alternator? Car has 66,000 miles on the original battery.
Old Feb 4, 2012 | 08:08 AM
MB-Dude's Avatar
'96 SL600, '05 S55 AMG, '06 C230
To me, the 12.0 volts running voltage suggests a charging problem. My cars are typically ~14 volts running. However, the battery might be drawing it down since you indicate the battery voltage is slightly *lower* with the engine running. Nevertheless, try having the battery checked first, since it's the easiest to deal with. Since it's ~6 years old, it's worth considering replacement; investigation, at least.
Cheers,
Jeff
Old Feb 4, 2012 | 10:16 PM
02S430's Avatar
W220 M113K
there is a recall on the voltage regulators that are on the back of the alternators check to see if that applies to MY 06
tusabes's Avatar
Mercedes
most auto parts stores can test both your battery and alternator on the car for free
Old Feb 5, 2012 | 02:03 AM
OCKlasse's Avatar
MBworld Guru
Thanks guys. Having my buddy check it out tomorrow to see if the alternator is performing as it should. I could not find a recall for MY06 voltage regulators. Thanks.
