How often...
Old Feb 18, 2012 | 02:15 AM
SFBIGBODY415's Avatar
2000 mercedes benz s430
How often...
How often do you guys use the raise feature on your w220's? Just wondering I barely use mine scared that airmatic will fail. But I use it here and there when I get it washed or on a really crappy road
Old Feb 18, 2012 | 03:22 AM
S600Keith's Avatar
S600
Use it when I park "nose in" to raise the spoiler above the curb.
Keith
Old Feb 18, 2012 | 06:05 AM
slopoke's Avatar
2000 s500
I live in constant fear of my airmatic too. I use mine on uneven terrain or sharp driveways. I use it when I need it. If it breaks, well then I will replace that part with an arnott one with lifetime warranty.
Old Feb 18, 2012 | 09:08 AM
stevedel's Avatar
W220
Almost never raise the car. Maybe the rare occasion that my wife drives the car, a really steep driveway or when washing the car so I can shine the tires.
Old Feb 18, 2012 | 09:23 AM
MB-Dude's Avatar
'96 SL600, '05 S55 AMG, '06 C230
Keith
+1 I'm paranoid about scuffing the bumper. Drives the wife nuts.
Cheers,
Jeff
Old Feb 18, 2012 | 11:43 AM
Quadcammer's Avatar
96 and 08 911 turbos
In the snow, thats it.
About the curbs...careful gents. On occasions the car will lower a bit when you shut it off, and you might end up dropping the bumper on it. If you leave to quickly, you may snag it and crack it.
Old Feb 18, 2012 | 12:18 PM
Sgt. Schultz's Avatar
opposite-lock...
deep snow only, otherwise never
I've learned to shallow park years ago so kerbing the bumper is not an issue
in my //S8, that was a *hugely* prevalent issue - sosososo many owners (er, always seemingly "the wife"?) hooked the front bumper on the parking stop, backed, up - POW! $2k repair (rips the entire bumper off / insideout)
no thanks
everyone that ever gets my keys gets read the riot act litany to SHALLOW PARK
anywho...
on the airmatic, one could Devil's Advocate that frequent useage of mechanical systems is GOOD for them - exercise if you will
I think there's a happy medium to be found there - use it sometimes, but not too often and not never 8-)
Old Feb 18, 2012 | 01:39 PM
haoz129's Avatar
MB 2003 S600. Volvo 2003 XC70.
Post
The Raising car botton designed to confuse us.
Actually it should be called Dynamic Mode 1 & Dynamic Mode 2, .
As by pushing it your car does not only lifted during low speed but also will be lowered even more during high speed.
Here is info from the manual:
No Dynamic Mode botton actived: No raise 0-60km/h, lowered 15mm 65km/h up;
Dynamic Mode 1: raise 10mm 0-60km/h, lowered up to 25mm 60km/h up;
Dynamic Mode 2: raise 20mm 0-30km/h, lowered up to 35mm 30km/h up;
For complete info please ref Manual under Control in Detail/Driving systems/ABC.
So I will push that botton when raise needed or before highway driving which can improve aerodynamic hence improve gas MPG.
But I seldom use it to get the bumper on high curbs as I'm afraid when I come back the bumper will be sitting on the curbs due to the struts can't hold their position, , just in case.
Thanks.
Howard
Old Feb 18, 2012 | 06:55 PM
Quadcammer's Avatar
Thanks.
Howard
Howard,
sorry my friend, but I'm not sure I agree with your logic.
If you raise the car 10mm in dynamic one and 20mm in dynamic 2, and then the car lowers 25mm and 35mm respectively, how is that any different than just lowering 15mm from the standard position?
I don't believe that any of the settings lower the car any farther than another when based on its standard height setting.
Old Feb 18, 2012 | 08:27 PM
haoz129's Avatar
Originally Posted by Oliverk
Howard,
Yes, Oliver.
I believe your logic is correct. I thought the more lowering is base on standard height.
So I confused myself.
Thanks for the clarification, .
Howard
Old Feb 19, 2012 | 01:46 AM
classyS's Avatar
2001 S430
theres been a few times ive accidently hit the airmatic raise button instead of suspension damper button before a long turn/curve, very idiot feeling indeed.
Old Feb 19, 2012 | 04:27 AM
Yeah if mine goes out then I will have to fix it. But I can't see me getting rid of the airmatic on the s class it's a big part of what makes our cars ride the way they do.
Old Feb 19, 2012 | 08:12 AM
Quadcammer's Avatar
Yes, Oliver.
Howard
no worries
Old Feb 19, 2012 | 10:40 AM
marktan's Avatar
2005 Mercedes S600, 2004 Mercedes E500 4-Matic, 2002 Mercedes C32 AMG, 2001 Trans-Am WS-6
I'll use the raise feature in heavy snow or when tring to get over a steeply graded driveway or if driving across and parking on the grass at some event venues.
To Howard and Oliver's point about the ride height and lowering, it basicly "Cancels" and is brought back to normal (-15mm from zero point/normal starting point) at higher speeds regardless of setting.
Old Feb 19, 2012 | 03:29 PM
Das Geld 2's Avatar
SL55, S500
The car is auto-leveling every second....
Old Feb 27, 2012 | 02:01 AM
Douglas Funny's Avatar
2004 S500
This.
Being scared to use the "raise" button because of failing airmatic is silly and pointless. If the airmatic is failing, there's no way you can prevent it by not using your "raise" button.
My 500 has 115k miles on it now and I've been taking all the air out of the bags when parked and filling them back up to enough that I can drive for probably 6k miles now, still going strong *knock on wood*.
