How to remove the air vent from the back of the front center console?
thanks
But anyways, what I did was get a flat screw driver and put it inbetween the wood trim and the actual vent. So I wasn't prying at the leather console, I was at the top of the vent inbetween it and the trim piece. I started applying very light pressure and it popped out and comes out with the 'din'. Then you can gently pull out the actual vent control. Be gentle and don't force it and you should be fine!
) figure it out that the AC in the back of the Car was not working . Please can someone help with this issue ?
