W220 S600 Wont stay running
The engine turns over every time, if given gas it will back fire, if floored it will stay running rough at around 1500 rpm. However immediately after will shut off. It will turn over every time then shut off once started. Just replaced all 24 plugs, problem persists.
Any help appreciated, not under warranty.
I just did my left bank in December...and just ordered the right one today. They can get damaged *very* easily when pulling them out to get to the plugs...it's also common for them to just go bad. They're about $1200/each, one for cyls 1-6, the other for 7-12. You could also check to make sure they were plugged back in properly when they were replaced, although the type of plug that it has makes it hard to not put it on properly. Good luck!
I suppose it could be something different, but it sounds strikingly familiar to what I went through after changing out my plugs. Get the malfunction codes checked, that will help narrow it down. If the light is flashing off and on, don't drive it.
Also pull the codes to see which side is misfiring. Cyls 1-6 are passenger side, 7-12 are drivers side. Code of P301-P312 with the last two digits indicating the cylinder that is having issues (P301 would indiate #1 cyl misfire, P309 is Cyl #9, etc.)
