How do you re-set Pre-safe, ABS, other errors on cluster?
Old Mar 18, 2012 | 07:34 PM
windycityxx's Avatar
2000 S500
I seen this posted in a thread and now that I did the brakes and replaced a headlight that was out, it still shows some of those errors..
What is the exact proccess to reset the cluster etc.?
Disconnecting battery should not hurt anything. Just a quick reset of windows and sunroof, then turn steering all way left and all way right to reset BAS, ABS and pre-safe errors that will show on your cluster
Old Mar 18, 2012 | 08:49 PM
Quadcammer's Avatar
96 and 08 911 turbos
should only need to hit the reset button on the cluster itself.
Old Mar 19, 2012 | 12:59 PM
2000 S500
I know there is a proccess like I mentioned to reset it, does anyone know the exact way to do this? Thanks!
The regular reset did not work
Old Mar 22, 2012 | 10:30 PM
hardwork s-430's Avatar
s-430 mercedes
WINDYCITYXX i have the same problem done my brakes 3 days ago pressed the reset afew time did not work. so im thinking of trying the battery dissconnect.
