HELP! transmission in limp mode, bad wheel speed sensor or possible bad tranny?!?!
1985 500sec, 1991 500sel, 02 clk430
my 2000 s500 will not shift out of first, i checked it with my friends scanner and its showing that the front left wheel speed sensor is not communicating with the car, and i also have code P0500 speed sensor, p0720 output shaft speed sensor, p0748 PRESSURE CONTROL SOLENOID.
i cleared all transmission and engine code but the car stays in limp mode, and the transmission code for left front wheel speed sensor comes right away.
my question is could this be caused by bad wheel speed sensor or is it most likely trannsmission problem?
