Rear lights error
Old May 17, 2012 | 12:06 PM
Tuscan1311's Avatar
S500 4 matic
Rear lights error
I was changing tail light bulbs but i brought the wrong one. When i put the old ones back in i get tail light error. How do i remove error from dash.
Old May 17, 2012 | 09:25 PM
frk203's Avatar
1985 500sec, 1991 500sel, 02 clk430
you have to have the right WORKING bulbs and then the error will automatically go away after you turn off the car and turn it back on.
if the new bulbs are not the exact right ones you will get the error back, and if the old ones are not working you will get the error.
also a common problem i have had with these cars is that the bulb socket will get dirty and would not get contact, which will cause the error, just make sure you clean the socket and the socket contacts have no residue on them.
Old May 17, 2012 | 09:50 PM
Tuscan1311's Avatar
S500 4 matic
Thanks i will try it when i get off work.
