Changing Pads and Sensors
04 S500, 05 Jeep GC, 06 Acura TL, 04 BMW 530i, 98 Jag xk8,
Hi guys, I did a search and found some great info, however I still need a bit of help.
How many wear sensors are needed for the brake job? is it two or 4? one for each wheel I assume? Also, do the pads need to be removed to put in the sensors? I had the pads done, but realize the sensors were never changed out. I personally did not do the job, however I am aware on how to do it.
Thanks in Advance.
this is an 03 S500.
Thanks in Advance.
this is an 03 S500.
Thanks in Advance.
this is an 03 S500.
Thanks in Advance.
this is an 03 S500.
If you really wanted to, you could change out the fronts without removing the pad, but you would risk breaking them, as they are cheap plastic.
It would only take a couple of minuets per side to change them out properly, IMHO.
PS: The sensors were cheaper at MB then they were at Autozone, go figure
2005 Mercedes S600, 2004 Mercedes E500 4-Matic, 2002 Mercedes C32 AMG, 2001 Trans-Am WS-6
My 04 took 3 sensors. Two up front, and one in the rear.
Thanks in Advance.
this is an 03 S500.
Thanks in Advance.
this is an 03 S500.
How weird, I just had my front brakes done on my S600. Gave the mechanic the rotors, pads, and two sensors to install. When done, he handed one of the sensors back to me in the package saying he just needed one (and the pads, saying I apparently ordered the pads for the rears...oops). I don't know if that means I only have one sensor, or if I have two and he re-used one (I was getting a "brakes return to workshop" message).
