DIY Oil Change Video
but I'd edit it.
1. Your lifting procedure is a bit odd and overly complex to me. The way I do it is to simply hit the airmatic raise button, and then slide the jack under the subframe lifting block. then you can lift both sides without the extra wood or jacking. you can also use ramps.
2. I'm guessing the people who will watch this are extreme noobs, so probably best to let them know to place a new drain plug washer on before reinstalling. Same goes for the rubber o-rings on the filter cap/assembly.
3. Drain plug on my car is actually 1/2", so to avoid rounding, both should be tried.
To get the filter on there easier, put some fresh oil on the top and bottom of the filter...no twisting required at that point, it just pops right in until you hear a click/thud.
4. quick tip, before you install the filter, pour the oil into the filter well. No funnel needed and you can pour in the oil as quickly as you want.
5. another tip, If you only have the front of the car raised, use a jack to lift the drivers side rear. This will get you another 1/4 of a quart or more drained out...bringing me to my final point.
6. the oil capacity with filter is 8.5 quarts or 8L with the filter.
I couldn't figure out how to get just one line on the filter to show even after doing the oil changes myself since '08, after this vid now I do.
Oliver has a good point, pouring the oil in the filter housing is a really good idea
Yes this video is directed towards beginners and actually I first tried to raise the car using the airmatic system, but I couldn't fit the jack under the bumper. Maybe the AMG bumper sits lower than the standard bumper?
driving the car onto the wood might work well also.
glad to see someone making videos on this kinda stuff though since many people need the visuals.
good job
