Need Rim Help
Looking to put rims on an 05 S500 4Matic, the vehicle has stock suspension and I really hate wheel gap. If you guys have an recommendations on offset, rim size and width it would help me alot.
We have a few wheels in stock for your application as well. Let me know what you are looking for.
On an AWD car, I think a square set up makes more sense. Staggered set ups are intended to give the rear drive wheels more bite. I'd be at 18 x 8.5 all around.
One way to deal with the gap is to keep your stock wheels and lower the car. I just did a minor drop on my S430 using adjustable links from Adjustable Air Ride. It was a very easy, tool-less install and took about ten minutes a side. I did the fronts myself and then had a local shop adjust the rears while the car was on the lift. (W220's have factory adjustable rear ride height).
Lowering will stiffen the ride a bit, but if you don't over do it the change is minor. Here's my car after the drop on 18's. About a 1" gap front and rear. The car feels like it's set on Sport 1 when its on Convenience, but hitting the "raise" button puts the car back at original level and the ride softens up accordingly.
Post a pic of your car and I'd be happy to give you some wheel ideas.
