What in the F
Old Aug 17, 2012 | 10:30 PM
Redw20855amg's Avatar
Blown 208 55 amg, 211 55 amg
What in the F
2000 s430
No gas, no throttle, engine wont rev up barely jumps 1000rpm when you floor it no codes whatsoever. Idles Perfect have allready replaced the following
Spark Plugs
Cats
Air Filter
Throttle Body
Throttle Pedal
TCM
Transmission Plug
Fuel Pressure is 100%
Compression is 100%
Leak Down is 100%
I dont know where to go next i also noticed durint TB replacement the butterfly on new and old TB wont open fully when you fully press pedal only maybe 1/5 of the way open so I can now only assume bad ECU Or this thing (linked below) Does anyone have ideas or know where the odule below is located?
http://www.ebay.com/itm/2003-W220-MERCEDES-BENZ-S430-THROTTLE-ACTUATOR-SENSOR-OEM-2205402545-/190690808021?pt=Motors_Car_Truck_Parts_Accessories &hash=item2c660ed0d5&vxp=mtr#ht_1011wt_718
Old Aug 19, 2012 | 06:16 PM
tusabes's Avatar
Mercedes
Classic symptoms of a bad electronic pedal but you say you already changed it?
