Shift points set too low -- adjustable?
Old Jul 21, 2003 | 01:59 PM
Jaeger's Avatar
My engine rarely exceeds 1500 rpm in the low gears. Can the shift points be reprogrammed?
Jeez, with the new 7-speed tranny, I'll bet the engine never gets beyond 1000 rpm until you hit the freeway. So you'll never even come close to those reported torque/bhp numbers unless you manually shift.
Old Jul 21, 2003 | 02:48 PM
Kar don's Avatar
Mercedes-Benz
Re: Shift points set too low -- adjustable?
how hard are u pressing the gas? The engine will only hold a gear with light throttle application IF you are using touchshift and manually select the gear. Otherwise the transmission will upshift to conserve fuel and gain speed. Drive it agressively for about an hour and it will change the computer settings to make the transmission react quicker and let the engine rev up before shifting. I still think you are too light on the pedal to be shifting at 1500.
Old Jul 21, 2003 | 04:33 PM
Jaeger's Avatar
Thanks Ali, I'll give it a try.
