analog clock time change
Old Feb 2, 2013 | 08:18 AM
salman62xx's Avatar
2003 clk 500
just got a used s550, 2007 from japan, how does one change the time on the analog clock....please help
Old Feb 2, 2013 | 06:15 PM
marktan's Avatar
2005 Mercedes S600, 2004 Mercedes E500 4-Matic, 2002 Mercedes C32 AMG, 2001 Trans-Am WS-6
If it's like the one on the e500, go into your command and set the time in there, and it will change the analog clock.
Old Feb 2, 2013 | 11:24 PM
salman62xx's Avatar
2003 clk 500
tried that, but it does not, the folks at Mercedes have told me that it will work thru the GPS.......find that a bit strange......but they might be correct
Old Feb 3, 2013 | 10:17 AM
wallyp's Avatar
2003 S500 2007 GL450
On my 2003 S430, the instrument panel clock is set from the GPS - I can set the time zone, and whether or not to use Daylight Savings Time thru Command, but that is all.
The analog clock on my Porsche has two tiny holes in the face - a toothpick in one sets the clock forward, in the other sets it back. I have never seen the analog clock in a Mercedes, so no idea whether it works the same way.
Old Feb 7, 2013 | 09:10 AM
salman62xx's Avatar
2003 clk 500
let me try this...thanks...GPS might do the trick.
Old Feb 8, 2013 | 12:52 AM
lylesr33's Avatar
Black 2008 S550 sport 2011 E350
I have the 550 also but I change the clock using the comand system. Go to setting (I believe) then time and set the time there and it changes the analog clock.
Old Feb 9, 2013 | 10:27 PM
salman62xx's Avatar
2003 clk 500
thank you all.....
