S600 - DAS Help, Constant Misfire on Cylinder 6
Now after plugs, head gasket and cleaner looking heads, i have a constant misfire on bank6, P300 and P306.
>>Idles rough. I have the DAS ( Star Diag ) working and need help to eliminate O2 Sensor, MAF or other sensors, before i blame the coil pack.
Need some help on what menu functions to go thru in DAS , other than running the QuickTest, also if there are expected values on certain sensors, i would like to
measure those and post as well.
2003 with 75K Miles.
Appreciate all help in troubleshooting this.
thanks
or you can go into acutations-t1 coil shutoff(something like that) and you can shut off leads a/b-max value= +5.
make sure that oxygen sensors are plugged into correct bank!
also go into adaptations,reset mixture adaptation.
, When you say , swap over to other BANK, can you do this using the DAS ?
If so, what options will get me there from the menu.
