Replace radiator fan motor?
Old Mar 5, 2013 | 05:46 PM
ayersl's Avatar
2000 S430
2000 S430; I am getting a louder than usual and progresively louder sound coming from engine. When I turn it off I hear something still spinning, and the culprit appears to be the radiator fan (it continues to spin after the motor stops like it has always done, but it makes a much louder noise than usual). It turns and does it's job, and I can hear the two different speeds as normal, but is making a higher pitched noise. I figure that maybe the fan motor is about to go?
I have searched threads, but have found no specific instructions and/or diagrams, etc. Can anyone give me advice and instructions as to what I have to do? It is way too old for dealer repair prices.
Thanks in advance
Old Mar 5, 2013 | 06:32 PM
drewk88's Avatar
2004 S600 Twin Turbo V12
I have seen just the motor for sale on a few euro auto parts websites, so you may not have to replace the entire fan shroud / controller / motor. If you can remove the motor from the shroud assembly, you could attempt to disassemble the motor and see if it's a brushless type and if it has replaceable bearings. The hardest part always for me, is having enough patience and smarts to disassemble the device without damaging it.
Old Mar 5, 2013 | 06:58 PM
ayersl's Avatar
2000 S430
Thanks! I found motors on Ebay for about $270, and an entire new, after market replacement assembly (motor, belt, pulleys, cowling) from Am Autoparts (on Ebay) for $265. I know nothing of this company, and have doubts as to quality and reliability at this price. Still, the price is tempting!
After looking at the assembly, I see there are belts and pulleys that drive the blade, so now I am not so sure that it is a motor problem. Motor does appear to run well, so noise could be some moving parts...???
Confounded! I think I may try to remove the assembly and examine the belt and pulleys before I pull the trigger on a motor.
I welcome all advice!
