help help help
Old Mar 21, 2013 | 03:40 AM
andy408's Avatar
2000 s430
help help help
i have a s430 year 2000 . every morning car starts find runs very good. as soon as i stop the engine it will just crank and will not start..i have to wait till it cool down and start again..codes come up as crank sensor ..i have replace 3 crank sensor and its the same problem.. the plug is good ..the wire
is good fuel pressure is good..i been on it 2 week allready. can any body help.
Old Mar 21, 2013 | 12:41 PM
trombone's Avatar
2002 S430
When you change the CPS there is a little protocol to teach the computer. Did you follow that? Something like let the engine idle and then run it 30 seconds at 3000 rpm and back again to a lower revolution. I am not sure about the exact figures, but if you search a little the forum you can find it easily.
Old Mar 21, 2013 | 02:02 PM
andy408's Avatar
2000 s430
i try it and it still the same . and i have search the forum could not find anything
now im replacing the fuel filter and cam sensor
will update soon
