S430 Air/Fuel Control
Old Apr 22, 2013 | 09:37 PM
tifosiv122's Avatar
SLS AMG | S65 AMG | GL550
We have a S430 and when she starts up she runs very rich (smell). What module /part controls the Air/Fuel ratio?
Thanks,
Erik
Old Apr 23, 2013 | 08:42 AM
Quadcammer's Avatar
96 and 08 911 turbos
There is no one module or part that controls this.
When the car is cold (below about 150 degrees of coolant temp), the engine control unit runs of pre-programmed fuel and timing curves (open loop). As you know, the car needs to run more rich when the engine is cold. Once the coolant temp hits that pre-set level, it switches over to closed loop, which starts to read from the MAF and the oxygen sensors in order to actively adjust the a/f ratio to get as close to stoich as it can.
If your car runs overly rich, it should throw obdII codes. If it doesn't, its likely operating as expected.
Old Apr 24, 2013 | 11:01 AM
tifosiv122's Avatar
It has been throwing CEL's - been like that for a while now. We've replaced the part that it was complaining about 3 times, with no luck. Now, when the car is hot - she won't start.
Drove her to the local mechanic - awaiting his diagnosis.
Thank you,
Erik
Old Apr 24, 2013 | 02:14 PM
Quadcammer's Avatar
what codes is it throwing?
