AC problem
Old Jun 17, 2013 | 02:14 PM
Gruboss's Avatar
2006 Mercedes S430 sport package
AC problem
Hi ,
In my 2006 s430
Ac , Low side is 85 psi and high side is 85 psi ,
air is warm from vents ,
need help with this one
Any one have similar problem ?
Sorry for my eng.
Old Jun 18, 2013 | 10:33 AM
wallyp's Avatar
2003 S500 2007 GL450
Low side should be about 30 psi, high side 150 to 300, depending upon outside temp and fan efficiency. If low and high pressures are the same, the compressor isn't operating.
With the engine running and AC on, visually check the center of the compressor clutch - if it isn't turning, the compressor isn't turning. Many possible reasons for the compressor clutch to not be engaging...
Old Jun 18, 2013 | 10:43 AM
Gruboss's Avatar
Hi , tnx for reply
it is precisely the problem, because the compressor clutch is currently running even with the ac off :/
