Used instrument cluster replacement coding & mileage question, pics
Old Jul 13, 2013 | 02:38 AM
carbizindio's Avatar
2003 C32, 2002 S55, 1999 SL500, 2004 S430
I plugged in a used instrument cluster with 30k miles more than the last, at the moment the cluster only shows dash marks on the odometer. I didn't do any coding. Did I make a mistake and add 30k miles to my car or would some type of adaption have to take place first?
I've read that only the dealer can change mileage but I found this menu in my SDS
the "setting main odometer forward and back" led me to some DAS info at which time I stopped.
Is gauge cluster mileage stored in this part of the cluster?
Old Jul 14, 2013 | 06:08 PM
well thankfully the miles didn't save when I installed the high milage cluster. I took only the lighting board out of the used cluster and installed it in my old cluster. Every thing is fixed now, the miles are back to normal and it looks like no coding is necessary.
Old Jul 15, 2013 | 11:05 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
can you take a pic of what PCB you swapped out?
