SRS code
Old Aug 11, 2013 | 07:36 PM
evansw220's Avatar
'01 S500 AMG Sport, ABC,Distronic,Rear Side Shades // '10 E350 P2, Pano, BLK/ALM,4MATIC Sport
SRS code
Hey guys/ladies, I have been messing around the coding on my 2001 S500 via DAS over the weekend. I changed a few codings in the Instrument Cluster(ICM) like turning on the convenience feature and turn off the tire pressures sensors since one of the batteries is dead. After saving the codings i noticed the SRS light on. There was a code in the ICM B111E-SRS able to communicate with CAN-BUS system. Tried going back to Standard Variant but nothing really changed. The code is Current and Stored even after trying to clear it. The convenience feature is still on also.. If any of you fellow members have any insights on resetting the coding or a fix for the SRS I would gladly appreciate it.
Old Aug 11, 2013 | 10:04 PM
jnash's Avatar
2017 S63
when you run a quick test and then clear the codes, make sure in the menu of SDS (aka STAR) you exit all the way out the to w220 chassis type selection and go back in again to check the code has cleared. If you cleat the quick test and run it again it will show the same errors as before if you dont do this.
