What is this fault code?
Old Aug 29, 2013 | 11:07 AM
jwalther's Avatar
Pressure is good in all four tires, and the car rides fine. My valve block on the driver's rear is going bad. The suspension has dropped overnight twice in the last five days. I'm working to get the warranty company to authorize the repair. Is this related?
Old Aug 29, 2013 | 11:51 AM
vmystikilv's Avatar
Range Rover
The Tire pressure sensor in you front left tire is bad most likely. This has nothing to do with the ABC suspension.
Old Aug 29, 2013 | 01:06 PM
jwalther's Avatar
Thanks. As soon as I read your response, I had one of those "a-ha" moments. I couldn't figure out what "FL" was, but obviously it's front left. I checked the pressure again, and it showed 29 psi. I put some air in the tire, and the fault code is gone.
Old Aug 29, 2013 | 04:36 PM
Fraser's Avatar
A Mercedes obviously!
I had the same thing show up when one of my TPMS sensors went bad. One trip to the dealer and it was sorted.
