electricity disappeared -00 320???
Hello.
I have a small problem my MB 320 S I turn the ignition key and nothing happens .Console is dark and the electricity does not turn on, thats why I can not read the obd what is wrong. I checked the air spring relays and then the ignition key stopped working. Before that everything is ok. Electricity comes to radio and fan normally. I dont find Finnish website anything like this. that's why I have to try the solution here. Battery is ok
Obviously some fault occurred when you
Checked the air spring relays
What did you do to check them? You may have done some damage
The guy is from Finland with a s320
I changed the wiper heater and airspring relay when this happened. But now i find 60A fuse passenger side footwell, which was broken. I try to find unbroken fuse tomorrow. Let's see what happen then.
