fuses assigment
Old Sep 8, 2013 | 03:00 PM
mykola's Avatar
s-430
Question fuses assigment
Hi,
I had pairing problem with my IPhone-5, I never had this problem before ( I had Motorola smart phone) It is starting activation but for 2-3 min sais "no phone connected". Sometimes it is works sometimes not.
My car is S-430 - 2004. Blue tooth adapter V60 located in cradle.
I decided to take apart cradle to check a connection. I spayed contact cleaner into female connector and I got luck!!! - my phone was activated just for 3 sec. All worked like before.
After that I decided to clean this connection better and unplugged a connection again. ( my bad!!!) One of the screw fell down exactly inside male connector and shortened between pins - I saw spars.
Now I lost whole Comand system - no navigation and audio as well.
Did I burn a fuse? Where is location of it?
Did I burn outputs on amplifier?
Please, give your expertise. Thanks, Mykola.
Old Sep 8, 2013 | 04:44 PM
corkshoppe's Avatar
Top Answer: 1
13's550/2000's430/13'gl63/'13's550/10's63
always check fuse first
Old Sep 10, 2013 | 01:01 AM
ibeforreal's Avatar
2003 S500 - Toyota Corolla (in the rain)
Check fuses 61 and 66 under the rear passenger seat. They control the command and radio.
Old Sep 13, 2013 | 12:33 PM
mykola's Avatar
s-430
Thanks for response.
I checked all fuses in the car and didn't find any burned one. Does Comand unit have a fuse ?
Thanks.
Old Sep 13, 2013 | 06:50 PM
ibeforreal's Avatar
Did you check the fuses in the rear of the car on the passenger side?
Old Sep 13, 2013 | 11:17 PM
mykola's Avatar
s-430
Yes! I did!
Under the sit on right side - there are two fuses one -10AMP another
30Amps both are good!
