e55 vs s600 (race video)
Old Sep 17, 2013 | 03:43 AM
iyad.2010's Avatar
E55 AMG W211
friendly run s600 VS E55 AMG
both cars are limited to 250km
e55 has a brabus catless exhaust
s600 muffler cut out
we did 3 run first and second run was in 2nd gear 80 - 250 km
3rd run was in first gear 50 - 250 km
( 10min between each run )
Old Sep 17, 2013 | 07:25 AM
vmystikilv's Avatar
Range Rover
You must have a non supercharged 600
Old Sep 17, 2013 | 07:55 AM
Zax63's Avatar
2006 s65. Ford Excursion 6.0. Pontiac GTO convertible. Porsche 944 Turbo SCCA car. Wife-E550 and 968
I assume you mean turbocharged. But regardless, the car weighs 600 lbs more and the e55 was under-rated at like 469 hp vs 493 of the s600, but its the same motor as an s55 which has virtually the same hp rating as an s600. Therefore the extra 600 lbs should factor quite heavily and this is an expected result. I suspect with a tune on the 600 vs. a pulley and tune e55 the tables would turn.
