I recently replaced the valve cover gaskets on the above car (both sides) also resealed pcv ventilation chambers. I want to give heads up to anyone who is replacing them. Replace the 4 hoses that connect in the ventilation chambers. Also replace the Engine Crankcase Breather Connector, mine broke off when i took it out. Take the MAF sensor, give it a good clean, replace the 2 rubber boots. Now its a good time to clean the Throttle body. After finishing them the car will be as good as new.
Here are the links for parts.
1- Engine Crankcase Breather Hose http://www.autohausaz.com/search/pro...reather%20Hose
2-Engine Crankcase Breather Connector http://www.autohausaz.com/search/pro...er%20Connector
3-Valve Cover Gaskets http://www.autohausaz.com/search/pro...Cover%20Gasket
This is the silicone to reseal the Ventilation Chambers http://www.autohausaz.com/search/pro...20Pan%20Gasket
Also buy 5 new M5x18 Stainless Steel Bolts, for the breather chambers (dont reuse the aluminium screws).
Here are the links for parts.1- Engine Crankcase Breather Hose http://www.autohausaz.com/search/pro...reather%20Hose
