Help on W220 swapping from Becker 30 to Command
Old Sep 26, 2013 | 09:51 AM
e_xtra's Avatar
W220 S320
Hi all
First of all Im sorry for bringing this forum up again but i cant figure out stuffs. So I need help! I have attached couples of pics included the diagrams and pics of the wires from the back of becker 30.
If i could figure out the wiring problem then i will be getting a command that comes with plugs and wire harness.
please correct me if i am wrong.
1. if i get the command that come with the plugs and wire harness. is it possible if i can cut the old wire out from the becker 30 and reconnect it back to the new Command unit by matching the colours?
2. I dont need any dvd or nav to hook up, Can the wire be left out?
3. I could figure out the connectors A and B from the diagrams that i have attached but on the connector C. What are those Blue, Green and White for?
4. From my pics. Do A and B wiring as it said on the diagram?
5. On the back of command that i will be getting I think i know where to wire the A and B. Maybe i can just plug them into the A and B connector without cutting the wire as i mentioned above? but for the C there's seem to be no where to put.
Please can anyone help me with this or at least tell me where can i hook up the Blue Green and White to.?
Thank you very much
Attached Thumbnails Help on W220 swapping from Becker 30 to Command-plug.jpg   Help on W220 swapping from Becker 30 to Command-b-plug.jpg   Help on W220 swapping from Becker 30 to Command-c-plug.jpg   Help on W220 swapping from Becker 30 to Command-becker-30.jpg   Help on W220 swapping from Becker 30 to Command-command-unit.jpg
Old Sep 26, 2013 | 01:19 PM
corkshoppe's Avatar
Top Answer: 1
13's550/2000's430/13'gl63/'13's550/10's63
how many plugs do you have going in to your old becker. your plugs will fit into the new unit but you will have to change out some pins, the pin outs are here on the forum look up command change out, its easy don't stress or youll mess it up.. 1 plug is the speakers that wont change, but the other are for sttering wheel controls and cd
Old Sep 26, 2013 | 01:21 PM
corkshoppe's Avatar
Top Answer: 1
you will also need an gps antenna and a speed unit, but your deck will work without seppd control unit
Old Sep 26, 2013 | 11:31 PM
e_xtra's Avatar
W220 S320
Hi I really appreciate your help!
At the back of becker
As shown in the previous pics, i have 3 plugs and 1 fibre optic (2 orange )
A connector (think its for the steering buttons, illumination etc.)?
B connector (for all speakers)
C connector (dont know what is it "Blue, Green, White" wire)
and 2 black cables 1 big head (Antenna?) and 1 silver head (new Attached pic)
thats all i have at the back of becker
you have also mentioned i need gps antenna and speed unit. however is it ok if i dont get it hook up? or else it wont work?
please send me some pics so i know how to start off.
thanks so much corkshoppe please reply soon
Regards Ex
Attached Thumbnails Help on W220 swapping from Becker 30 to Command-2010_02170013.jpg
Old Sep 27, 2013 | 09:44 PM
corkshoppe's Avatar
Top Answer: 1
1 is antenna for fm and 1 is radio, the radio will fit the gps will not, you can buy gps online for 15 bucks and just put in the dash, the b plug will fit in to new command, the wires in c will go into the new unit but the order has to be different, im trying to find wiring harness for becker 30, please look on here for command 2.0 upgrade it will tell you everything you need to know but we need to find out becker wiring harness. my email is coekshoppe@gmail.com email me.
