Please help with wheels bolts size 18x8 .5J ET +48 do they fit S430 '04
1 Post
ML350 '06 & S430 4Matic '04
I found these wheels and tires 245/40 18" with W212
18x8 .5J offset ET +48 18" from Mercedes E Class Factory Wheels OEM E350
Do they fit with my car 225/55 17" OEM wheel offset 40 or 44 I'm not sure?
IF they're fit. Can I reuse current lugs bolts? or neet to buy new ones and what size should I buy?
Please help ASAP my current tires can explode any minutes.
Thank you so much for any of your help/knowledge.
MB 2003 S600. Volvo 2003 XC70.
![Exclamation](https://mbworld.org/forums/images/icons/icon4.gif)
Safety first.
While I agree with 129's theoretical caution the practical reality is that the wheels will fit but will pose a clearance potential due to the different ET's. Search the forum and you will find a post that allows you to enter various combo's and points out the potential clearance issue
the bolts will fit but the wheel will sit deeper in the wheel well so i would get spacers and maybe a little longer mb bolt. but try it it will fit. if you have a lower et the wheel wil fit flush with the body.
