Instrument cluster issue
Hi,
I'm still experiencing issues with my instrument cluster on an 01 S430.
I just got my cluster back from BBA-Remanufacturing, but when I plugged it in I still don't get any lights or movement on the gauges. I've checked the fuses and they all look good. Anyone got a suggestion about what steps I should take next?
1 Post
1981 W107 500SL
I'm still experiencing issues with my instrument cluster on an 01 S430. I just got my cluster back from BBA-Remanufacturing, but when I plugged it in I still don't get any lights or movement on the gauges.
The car also doesn't automatically lock anymore while driving, and the lighting on the dash buttons/AC/GPS/seats etc are not working.
All I took out was the instrument cluster. It only had one connection. It randomly died while driving a few weeks ago. At first a fuse had blown, which I replaced. It then worked for about two weeks, before it died again (no blown fuse this time). I sent the instrument cluster in for remanufacturing and received it back today. When I plugged it in, it still wasn't working.
Could it be a CAN bus issue I'm looking at here?
http://static.ibsrv.net/mbworld/Can%...2010-28-02.pdf
I actually took it out myself and sent it in to BBA-reman, which I heard is a fairly decent company. They said that they replaced some capacitors or transformers that had blown in the cluster.
2014 S550 4matic
The problem is that the instrument cluster isn't working as well. I'm also talking about all the lighting in the cabin, not headlights. All illumination for buttons, switches etc. do not work.
Were all the other lights working before you had the problem with the instrument cluster? For some reason I thought the instrument cluster had to be reprogrammed by the dealer or Star diagnostics when it was replaced/repaired.
If the cluster is the same one that was programmed for the car, and has only had the electrical repairs made - would it still need to be reprogrammed?
It is also the same cluster that the car came with, so I don't think it would have to be reprogrammed? The cluster is also not showing any sign of life in my car.
I was looking at this PDF of the CAN system, and was wondering if I may have a problem with CAN B or C
I heard BBA is pretty reliable, but I've never dealt with them before. I'll give them a call tomorrow and ask just to be sure. I dropped the car off today at a shop to make sure it's diagnosed correctly. Is a SAM replacement a possible diy job?
