any important differences with these pse pump part numbers???
ok, so i'm looking for a pse pump for a 2000 s500 and I have found quite a few that look exactly the same, with the ports labeled exactly the same and electrical connectors the same, but the part numbers vary. Is it ok to change my pump for one of these units that isn't EXACTLY the same part number?? The one in the car is 220 800 02 48. Part numbers I have found so far that are for pse pump that ALLEGEDLY are for s500 are as follows:
220 800 08 48
220 800 07 48
220 800 05 48
I believe these will all work on the vehicle, but I just want to be sure before purchasing. thanks in advance
220 800 08 48
220 800 07 48
220 800 05 48
I suspect they are compatible upgraded part numbers. You really need to subscribe to the free online EPC service http://epc.startekinfo.com and check or ask your dealer.
2002 S430
autohausaz.com part search brings up the the same pump of theirs for both part numbers
220 800 08 48
220 800 02 48 (yours)
which pretty much verifies they are compatible
220 800 08 48
02 48 replaced by 05 48 replaced by 03 48 replaced by 06 48 replaced by 08 48 replaced by 07 48 replaced by 10 48 replaced by 11 48 replaced by 12 48 !!
Guessing any would work, but higher number liable to have most improvements. Couple links for sourcing >>
http://www.autohausaz.com/search/pro...=18@Electrical %26 Vacuum&gid=5172@Vacuum Pump
http://www.pelicanparts.com/cgi-bin/...FcTm7Aodw28Apw
