Alternator Replacement then Performance Problem
Had a problem with battery check loading on dashboard appearing then going away.
After alternator change all okay message gone and car starting okay.
However after getting car back it is performing sluggish. As soon as motorway drive it doesn't go over 2,000 revs.
Once first started it can go over 3,000 revs but very slowly. It is as though it feels heavy. No real performance. Does kick down. As soon as on motorway cannot go over 2,000 revs and no more kickdown. It seems as though something is blocked
The guys at the garage are awesome. They said they fit everything back together and when doing it the transmission line needed replacing which they did and put back in the transmission fluid.
Please could you do tell me what this issue could be. Also the car is using a lot more fuel . My car is a 2002 s320cdi.
PICTURE of the line replaced.
I also had a problem with the engine not shifting into 3rd gear. I found out I had to do a reset With the vehicle on I turned the steering wheel all the to the right and then all the way to the left. I did this 3 times. Then I turned the car off. When I turned it back on the fault codes were off and the car drove great.
Give it a try. Good luck.
[/IMG]
